G
It feels like handle comes up too much before I feel much resistance. Picture is at bottom stop.
Manual specifies 40-65 mm of play before resistance is felt pulling up handle.
I measure 35 mm up from stop at ~50 mm before lever on back caliper starts moving.
But there’s no real resistance at that point. Going by feel, I feel resistance at about 65 mm above bottom stop. Lever goes back down to 20 mm from stop and has to be pushed down the rest of the way.
Would play be the 35 mm before lever at back starts moving (tighter than 40-65 mm spec in manual), or 65 mm where I start feeling resistance (and at upper limit of spec)?
Is this play adjusted via wing nut where cable connects to lever at back caliper, or elsewhere?
