P1000 Passenger speed sensor
Big nash
14
I pulled my passenger speed sensor in it had a dent in it could that make my I4wd not work?
107,602
Never hard of a passenger speeed sensor? But then again, i have a 16’ none of that stuff is in there.
to answer your question, I dont think that would make your i4wd to not work.
I do have a question tho.
You said in an earlier post you have a Green 20’ LE. Never seen one before at least not in hunter green. Do u have that metallic green?
see this is why we like pics when u join. So… Pics Or It Didnt Happen! ;)
Big nash
14
It is the metallic one well was
0161399C 253E 4E12 93B4 D0DDFDE7015F
bumperm
bumperm
1,851
6,657
Gardnerville, NV
If the pax side speed sensor gets dented, it's been known to turn your whole world akilter - as shown in your pic.
The speed sensor lets the i4WD know when a wheel is loosing traction and slipping, it then applies braking to the slipping wheel so that power is redirected towards the opposite wheel that has traction. There are arguments about the advantages of i4WD vs. regular diff-lock 4WD. Both work well. But while locked diff locks can cause plowing in loose surface cornering, making steering feel clumsy, i4WD helps pull the front end through those turns - - unless you have a dented speed sensor, then all bets are off.
107,602
Well scratch my belly and call me Shirley! I Stand corrected, had know Idea about that part
Big nash
14
Dent where?
In the tip? Or the side?
Tip
yep just broke my front drive shaft
