P500 Philips head screws under seat
O
Ojiohoundog
I had the same problem.
An impact screw driver you hit with a hammer did the trick for me.
This is a tool you will need if you do any work on the motor also.
I know it was not corrosion. brand new running wires for lights.
NTC/TAP Transition Member
11,885
90,617
After using a hammer impact screw driver on those screws, I just cut an oil filter access hole in the plastic to avoid a repeat. @trigger Shield covers the hole.
Mopower58
Mopower58
Unburdened by what has been!
88,355
756,075
Crystal Springs,Ms.
For future reference, hopefully not needed. An impact driver or if not available, valve lapping compound applied to the bit, for more grip on the screw, a firm downward pressure,and vice grips on the shaft of the bit to aid in turning.
The Green Goat
The Green Goat
2,440
17,968
I took them apart when mine was new, and put anti-seize on them. Now I can take it apart with my tongue.
Edit: Thumb*
