I thought I would put together a list of use full service facts for the Pioneer 1000. This will come in handy a lot when wanting to know what kind or how much of something.
Engine Oil
Oil Filter Part # - 15412-HP7-A01 Buy one here --> http://amzn.to/1Qxj6tb
DCT Oil Filter part # 15412-MGS-D21 Buy one here --> http://amzn.to/1Qxj9oV
Honda recommends a API classification of SG or higher, do not use oils labeled as energy conserving or resource conserving.
- Viscosity (weight) SAE 10W-30. Other approved colder weather areas can use 5W-30, or 0W-30
- JASO T 903 standard - MA
- Suggested oil - Pro Honda GN4 4-stroke oil or Honda 4-stroke oils or and equivalent 4-stroke motorcycle oil.
---- 5.5 liters (5.8 US qt) after draining.
---- 5.7 liters (6.0 US qt) after draining and engine oil filter change.
---- 5.8 liters (6.1 US qt) after draining, engine oil filter change and DCT oil filter change.
---- 7.2 liters (7.6 US qt) after disassemble.
Sub-Transmission
- Viscosity (weigt) SAE 10W-30. Other approved colder weather areas can use 5W-30, or 0W-30
---- 1.2 liters (1.3 US qt) after draining.
---- 1.4 liters (1.5 US qt) after disassembly.
Differential Oil:
Use Honda shaft drive oil or equivalent hypoid gear oil SAE 80.
- Front
---- 11.5 US oz at draining
---- 16.9 US oz at disassemble
- Rear
---- 15.9 US oz at draining
---- 18.6 US oz at disassemble
Fuel
Honda states that only unleaded fuels can be used in the Pioneer.
- Fuel tank capacity - 7.9 US gal (30L)
Coolant
Honda recommends using only Pro Honda HP coolant. However a equivalent high-quality ethylene glycol antifreeze containing corrosion protection inhibitors specifically recommended for aluminum engines can be used.
- Solution 50/50, 1:1 mixture with distilled water.
- Capacity:
---- 3.2 liters (3.4 US qt) at drain/replacement.
---- 3.5 liters (3.7 US qt after disassembly.
- Fill reserve tank to between Min and Max level.
Spark Plug
- Standard spark plug - SILMAR7A93
- Gap - 0.031 - 0.035 in (0.8 -0.9 mm)
Brake Fluid
- Honda DOT 4 brake fluid or equivalent DOT 4
Battery
- GYZ16H = 12v - 16Ah/10h.
Engine Oil
Sub-Transmission
Differential Oil:
- Front
- Rear
Fuel
Coolant
- Capacity:
Spark Plug
Brake Fluid
Battery
