P1000 Pioneer 1000-5 fan not working
Jamorrjr
7
Florida
My pioneer 1000-5 overheated the last ride we was on, boiled coolent out. Fan is not coming on, check connection and plugs, looks good. Wanting to test fan, unplug connector at radiator, green and blue wire. Which one is hot wire.
Reactions: ChadD and Lady01
Neohio
Neohio
Beast of the East
14,591
73,894
Painesville Ohio
Do you have any older headlight bulbs? Use one to test the Honda wiring side.
If I recall, early 17 models needed an update to correct a cooling issue.
tjoreo
tjoreo
1,025
1,972
Southern Idaho
Just curious what year of machine? A friend of mine contacted me this morning and said he had the same problem. 2018 and earlier had a problem with the fan coming on. It took a reflash of the computer to correct this. I have a "18 and I had it happen a couple of times. After the reflash it hasn't done it since. The friend I spoke about also has a new to him 18.
Sent from my SM-G781V using Tapatalk
66,881
Either will work. It will just reverse.
But, blue is hot for correct flow.
115,793
Thanks guys, fan did work when hooked straight to battery. Now the fan is coming on like it should. Must have been in connection, after disconnecting and testing fan it seems to work now. It’s a 2019
2019 Cool!
PICS? #POIDH
  • Haha
Reactions: ChadD and Rayger143
tjoreo
tjoreo
1,025
1,972
Southern Idaho
It does look like an early 19 could use the ECM reflash. Here is what I could find. Hopefully testing and reconnecting the fan solves your problem, but if it happens again you might want to check on this thread.
Rayger143
Rayger143
3,098
27,202
Winfield, BC Canada
I would get 1 of these from club store. I have it and use it.
Seth14
Seth14
66
407
53
Indiana
Just a thought…..but my little brother had a 2018 for 3 years……he specifically told me when I turn the key on, what for “Hello Honda” to come and go and the temp gauge actually pull up before starting. Not doing so would cause something in the computer to bypass the fan. Happened to him one time and never again since he did that process.
Reactions: 0860silverado
