Pioneer 1000-5 top
Pellicer96
Pellicer96
75
166
Lyons
Would like to hear of comparisons and opinions of oem roof and a flat aluminum roof pros and cons
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
I made a flat aluminum roof out of 6061 aluminum. It was very durable and worked great. The problem was when a branch caught the visor or hit the top it would ring your ears. It was pretty loud.
I now have a top made of 1/2" HDPE. I made it a little extra wide and it works great as a rub rail on the top of the roll cage. Its quieter and absorbs the impact of branches much better. Both options are heavy enough to stand on, and another bonus is you can screw a dome light to the roof and not have to worry about fasteners on top or making holes through the roof as I did with aluminum. I really like it and would recommend the HDPE route.
Reactions: Landman
Pellicer96
Pellicer96
75
166
Lyons
Thanks for feedback do you have any pictures by chance I I think the heat was my biggest concern with aluminum getting to hot during riding
Bradley-Thornton
Bradley-Thornton
684
1,648
Hattiesburg MS
One of my favorite upgrades was adding a Alien Sunshade off Amazon. It also lets you put the OEM on when you need it (Rain)
I like the idea of the aluminum one but it will reflect more motor and transmission noice then the OEM and that way more than the Mesh style.
https://www.amazon.com/SUNSHADE-Pioneer-Warranty-Provides-Protection/dp/B078YDYN3J?tag=sxsweb24-20
54716137503  589D9CCD EDAE 42CF B0B3 8C2997B8ED6A
Reactions: HondaRed16
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Pics C94ad0dbd4e27f4e0e91fc5b1124301012ccaec805eec65d3b5593b68c59a15b68c2495d8924e19281633dc2d7e027bc8f35dfac8ec179143530ed41df05c34d
Firemedic530
Firemedic530
386
1,122
West Jefferson, Ohio
I have the OEM and it is very durable. I use it to pivot around trees and have rubbed some rocks as well with minimal marks. My only complaint is that the front center holds water and dumps it down the windshield when you move. Minor problem.
aauman88
aauman88
1,091
2,846
I say get custom roll cage built with integrated stereo roof pushing about 10,000 watts
320,450
I totally agree with you on the factory option. Love the way trees slide without damage.
On water issue I did chop more on front cage to eliminate this but you could probably lower the front mounts and slightly raise the center to correct that issue
Reactions: Firemedic530
