PIONEER 520 HIGH-CLEARANCE 1" FORWARD OFFSET A-ARMS - SuperATV
SuperATV
SuperATV
1,351
9,391
Madison, IN
www.superatv.com
PIONEER 520 HIGH-CLEARANCE 1" FORWARD OFFSET A-ARMS​
Gives you room for 28” tires without a lift!
Link:
  • Adds 1” of forward offset
  • Fit up to 28” tires
  • 1.25” tubing is larger than stock
  • Adjustable pivot blocks for full camber adjustability
  • Utilizes stock A-arm bushings
  • UV-resistant powder coat finish
  • Easy to install
  • Backed by lifetime warranty
Honda pioneer 520 a arms 1
Honda pioneer 520 a arms 2
Honda pioneer 520 a arms 7
Beefy!!
Honda pioneer 520 a arms 8
178,147
@trigger We need to test these
Yeah I saw this when he posted yesterday. I already have the OutKast arms on which are supposed to be 3" forward. They also raised the front end about an inch and a spacer was provided to put under the differential. All said and done it got rid of the axle bump on the passenger side. Got me wondering if this will do the same or make it worse? It says it utilizes the factory bushings but you'll still need ball joints. Getting the factory one's out was a no go for me, went with All Balls.
These do look beefy and are about half the price of what I paid. You gonna be the guinea pig?
rustyneversleeps
rustyneversleeps
383
1,835
Montana
It looks like my new arms are already delivered to my front door.
Now that’s some quick service!
Rob
Rob - expecting pics ;) I’m curious how long install will take you and any blockers or issues you run into. Been looking forward to someone coming out with t-Rex 520 arms for a while now….now if only hard doors…;)🤣
178,147
I will document the process as soon s I get started. I have a pile of new parts that need to go on: a-arms, skid plates, locker, turn signals/horn and power steering. So many parts and so little time
No experience with these particular A arms but something I had to deal with was camber after install. We have no camber adjustment on these other than the preload on the springs. Another thing to pay attention to is axle bump on the passenger side. The older P5's sat a little higher and would do it from the factory. Mine did until the A arm swap, now it doesn't. 🤷‍♂️
crewcabrob
crewcabrob
1,029
4,039
Omaha
Thankis for the advice! I already talked to a buddy to get this on an alignment rack when I have it finished.
mom trying to decide if I want to eat until my Ella shocks get here before I do everything. That way I drag it to the shop one time to check the alignment.
Rob
