Pioneer 700-4 With Hard Top Roof Height
Computergal2104
I'm wanting to purchase a Pioneer but am concerned with the machine's overall height especially with a hard top roof. Can anyone provide me with the height with a hard top roof? Also, how does the machine ride with a bimi? I'm concerned because my storage building door will only allow for 80". Thanks in advance!
I have a 3" Lift and 27" Tires so roughly 4" over stock and I rub the hard roof on a 7' Door with the rear preload on the stiffest setting. I could probably lower the preload and get it in and out.
19712680f6bd6cd9621a72d4edee19a0
scott
scott
1,212
1,354
lyman, South Carolina
There is a metal roof out that isn't as high. Don't remember who makes it.
Tflynn
Tflynn
Not a liberal
2,501
3,833
Northern California
Extreme metal products makes an aluminum roof. Could be the one you're thinking of
allgm1
allgm1
1,049
1,484
New Hampshire
thats strange, I measured mine last night, bone stock '15 p4 with 9psi in the rear tires and mine measures 81 1/2" not mus lower than yours with bigger tires and lift????? you must have some mud caked up in there somewhere?
No mud and as of this pic few accessories.
I only was only running 5psi for in the tires, with that in there they only measured 26" so inflate them and you're at 83"
This is stock
F2c28a9bee3dba42b827d9ae3b4cfd39
10238783950f35b3d25f00c28f4a9465
With lift and tires
E2d98e79dc5a7d40e9f5ce5f085e231e
2978186068a8eacfb25daaf935344ecf
Unsettled with lift and tires (lowered off jack and not moved pic was taken as part of an argument)
C2a406eb92bcf88d6d0d977f6dd30116
My tape measure is old it might have shrunk.
If I measure it now I've got about 350-400lbs of adds between winch, skids, a-arms, fender flares, optima battery, 20lbs of wiring, spare tire carrier, tools( For Polaris), recovery gear(for other Polaris), gas can, 2" ball, Honda Cab bits(roof, glass windshield, wiper, washer, hard mid panel, all4 soft doors, rear panel), 3 light bars, led cubes, heater, stereo,
But I also have spring spacers on the front (for now, about to put 2015 shocks on) and I'm waiting on fedex to deliver 28" Blackwater EVOs.
Reactions: caverat
scott
scott
1,212
1,354
So with lift and tires. You are right over 14" ground clearance? Is that with all the stuff you carry in it?
14" unsettled just lowering it off the jack, 12-½ if I ride it around for a min and park it.
Yes with all the stuff I have in it.
My Evos came in this morning along with my 2015 shocks, once I get them on I'll have a new measurement.
Mabe
Mabe
21
A
Ashley2009
5
Clarenville
Do anyone have the 2021 pioneer700 4 seater. that can tell me if she fits in a 7 foot garage door opening
hacksawjoe
74
150
Mill Hall Pa.
we have 2015 700-4 with hard roof and I take it in my daughters garage with 7 ft door to change fluids fits fine
Hondabits
Hondabits
11
6
2020 P700-4D stock with hard roof and it fits in my 7 ft (83") garage door with an inch or so to spare with the stock roof mounts. I then did the bracket flip on the center and rear mounts and picked up another inch or so. If I had to do it again, I'd look at the flat steel roofs that are out there, in anticipation of installing bigger tires / small lift.
