pioneer 700 wont start
T
Thelma1994
6
I have a 2014 honda pioneer 700. I used it to plow snow and haul wood every other day. It has 307 miles on it. When it's cold it works fine. When it's warm, it loses speed to around 13 mph. If you press the gas pedal, it sounds like it's starving for gas
63,544
Hummm...
Have you given it a basic check over? Oil level ok? Is the filter ok? Is air flow being restrictive? Does it change gears? Is the display flashing?
Oh... How about the muffler? There were a few problems with the muffler. Take the rear baffle plate off and see if it looks ok. Look inside at the plate inside. Is it loose? See this link- http://hondasxs.com/index.php?posts/7640
A
Alvin
Louisiana
Thanks. I removed the fuel hose and engaged the fuel pump and straight water poured out. Once I got all the water out, it ran fine.
Reactions: Hondasxs
T
Thelma1994
6
Yes I checked fluid levels. I checked hoses for kinks and wires for connections. When I first had the probleum the engine light flashed ant the tempurature light stayed lit. With the key on or off. I unhooked the neg battery cable and reconnected it and that solved that. I took the machine to the shop and they are working with honda on that. I didn't expect the muffler because it was new and only had a few hundred miles on it. When they find out the probleum I'll post it here
Reactions: Hondasxs
T
Thelma1994
6
I got a call from the shop where my 2014 honda pioneer is getting fixed. It was the muffler and now they are waiting for a response from honda, to see if they are going to cover the bill or not. They put the big reds engine in the pioneer, why not the muffler too
