Pioneer front shock adjustors
hondabob
1,238
4,876
Prescott Valley, AZ
I used these on my 2009 Big Red. They fit ok on my Pioneer and I get about 1/4 inch of preload with them installed. That makes a noticeable improvement. The first notch gives another 1/2 inch of preload and that works well for aggressive higher speed driving. The 2nd notch is another 1/2 inch and that position may be only good high ground clearance for snow or mud riding. The suspension will be toping out a lot but its a cheap lift kit for low speed riding.
The rear shocks have 5 positions and that gives about 1/2 inch of preload and is enough for most loads and driving.
http://www.t-m-2.com/index2.php
66,437
Ya. That will work great. I haven't seen these before. Will check them out. Thanks.
42,680
@hondabob do you know if these are still around? Link is dead and I'd like a touch more ride height up front.
