P1000m5 PIONEER ROOF MOD!
Dubfab
Dubfab
58
107
Pennsylvania
Buddy of mine showed me his side-by-side with his homemade roof and I was amazed
Today I start trying to copy what he did.
Basically is a fleece blanket of your pick stretched out over top your buggy using 2 x 4‘s as weight reinforcing the sidewalls of the top of the roof fiberglass matting. You need to make struts somehow support the underneath with either pieces of wood or whatever you can find to give it strength whenever you apply the fiberglass resin found it any auto parts store.
Today is the first night I am trying to get this project started I will post pictures as I progress with this roof build
Dubfab
Dubfab
58
107
Pennsylvania
1071BFE7 18EF 47AF 827B 3EBACCAB8380
4239ECC7 EE47 478F AEA1 C88DB7DB1F78
299059C2 DAB2 4129 B906 828298E9BB26
23E30FF5 1FDD 45A7 8E26 A3376C4FC7D3
Dubfab
Dubfab
58
107
Pennsylvania
Just make sure that you staple down fleece blanket two 2 x 4’s and add weight if needed to stretch it out over top of your buggy
208,720
OK??????????????????????????????
Reactions: pct
jinx
jinx
565
528
Possibilities are endless with that process once you figure it out.
I'd definitely do as Dubfab suggested the weights will help stretch it out plus hold it taut when you add the weight of the resin.
I'd be tempted to add in some wood furring strips on the bottom to mold in for added strength. Could even build in some stereo/speaker pods, a wire channel and on and on....
Dubfab
Dubfab
58
107
Pennsylvania
So this is a spur of the moment weekend project that may stretch into the week project
208,720
Ya know add weight so that the edges of roll bar and fleece are uniform and will make an easy cut on finished custom project
So the original roof is just a mold?
208,720
Yea u would stretch it to mold to ur roof contour
Advise that u put down plastic over top just in case it seeps thru
I would just get a hold of Walter and have him make graphics for the roof, less weight, you know float like a butter fly, sting like a bee!
Dubfab
Dubfab
58
107
Pennsylvania
I’m going to use this “mesh” around the outside edges of the roll bar for when you hit trees or whatever
5F2A546D BEFC 4792 9904 DEA5586BCA3B
Reactions: BWAF
jinx
jinx
565
528
The fleece blanket will become the roof once it's saturated with the resin and cures.
I've never molded anything this large, mainly speaker enclosures etc
Edit to add that if I'm understanding correctly, he's stretching the fleece over the bare ROPS then applying resin to make a DIY roof
Reactions: pct and Tramguage1
BWAF
BWAF
I get paid to pass gas
8,860
42,462
Carthage MO
Can't wait to see it done !!!
Sent from my SCH-R890 using Tapatalk
Reactions: pct
Dubfab
Dubfab
58
107
Pennsylvania
So it was hard spreading the resin using a paint brush I did use a can of auto parts .8 gallon can with harder included so went thick on the outside edges it looks sloppy but I made sure I had enough fleece material to reach down and around the roll bar so once it’s finished I can cut to fit.
My plan now it to have garage heated over night
Once the fleece is hard I’ll lightly sand and apply another coat
Hopefully it will spread a lot easier tomorrow
Final coat will be HERCULINER
771CDED7 3729 47C4 BBF8 123BF0D4EE25
B03F5169 5729 4D0B A003 ECF464DE0292
BWAF
BWAF
8,860
42,462
Carthage MO
View attachment 66256 View attachment 66255 So it was hard spreading the resin using a paint brush I did use a can of auto parts .8 gallon can with harder included so went thick on the outside edges it looks sloppy but I made sure I had enough fleece material to reach down and around the roll bar so once it’s finished I can cut to fit.
View attachment 66253View attachment 66254
Looking good
Reactions: pct
Similar threads
