P1000m5 PIONEER ROOF MOD!
ToddACimer
ToddACimer
Pioneer 1005-2
3,745
15,854
Oshkosh, Wi
It looks pretty flat on top. Are you worried about water pooling on top of it?
Dubfab
Dubfab
58
107
Pennsylvania
I’m not too concerned about water
It doesn’t sit outside. And if it does
Thought about it and with this type of roof experiment I accepted that I may get a wet lap once in a while.
Reactions: BWAF
Dubfab
Dubfab
58
107
Pennsylvania
OK let it dry for around 24 hours it was still a little bit tacky in some spots but most of it was dry I apply the second coat tonight and it went on a lot smoother still used a little bit more than a half gallon of fiberglass resin you can tell on the first pass that some of the fleece material didn’t take a lot of resin but on the second pass it soaked it up.
Since I have the plastic draped over the rollbar first I put a space heater in there since I ran out of propane last night hopefully the heat overnight into the next day will help it cure a little bit faster hopefully In two days I will post my kid standing on the roof fingers crossed hopefully
Reactions: BWAF
Dubfab
Dubfab
58
107
Pennsylvania
D22CD4F7 C72A 4531 911A 48386B6B36EF
Here is 2 heavy coats of fiberglass resin sanded down doesn’t have to be flat obviously you could see the inconsistency of the two coats
Picked up more fiberglass matting going to spread it over the entire top and it’s more coats take a little bit longer to dry but this second coat one a lot easier and I Soum the third coat with a fiberglass matting will give it a smooth top I’ll post when I get to it
BWAF
BWAF
I get paid to pass gas
8,869
42,494
Carthage MO
View attachment 66638 Here is 2 heavy coats of fiberglass resin sanded down doesn’t have to be flat obviously you could see the inconsistency of the two coats
Looking good. Have you thought about a raised batman emblem?
Sent from my SCH-R890 using Tapatalk
Reactions: pct
Dubfab
Dubfab
58
107
Pennsylvania
8F6B0A65 165E 4458 A6B3 69A426DCBC8B
4A8FEE0F 297B 4C6F AAD1 F242A9ED5029
So for the third coat went and bought four packs of the fiberglass mesh I stretch three out keeping the last one for the final coat hopefully the final coat will give a hardness where am I have to go and get another gallon of fiberglass resin until it’s tough enough for the trails here is before and after the third coat
Dubfab
Dubfab
58
107
Pennsylvania
I’m not that technically inclined to do the raused Batman emblem
Food for thought if you wanted to go and get you them LED weatherproof strips I would imagine they’d be fairly easy to embed into the roof that’s something I might end up doing
Reactions: pct and BWAF
BWAF
BWAF
8,869
42,494
Carthage MO
That's a good idea dome lights driving lights and all or radio
Reactions: pct
pct
pct
Lost in the hills
790
1,023
Letart WV
You have been a busy boy looking good. How bad are you itching HaHa Nice work are you going to mold in a stereo setup too
Reactions: nbomar and BWAF
moparornocar
moparornocar
RIP....Rocmar...
4,606
12,493
Augusta, Wisconsin
Looks great man. Can’t wait to see the finished product. It’s making me itch just looking at the pics lol.
Reactions: BWAF
Farmer
Farmer
2,973
17,161
Southern MO
You could trace the symbol onto some cardboard, transfer that to some 3/4 plywood, cut it out with a jigsaw and fiber over it. I like the batman theme but it seems you were just using the nearest old blanket that you had around. Never mind me, just trying to make more work for you! LOL!
Dubfab
Dubfab
58
107
Pennsylvania
It was a busy Friday for me finally got time to put more measure on the outside edges of the rollbar and apply the fiberglass resin on it I will let that dry and then I will ply another coat over everything let it dry and then probably use a bedsheet for the final top layer and use fiberglass resin the seal it in
Reactions: BWAF
Dubfab
Dubfab
58
107
Pennsylvania
CBBD1BB0 98B1 443B 98B0 93CA6E5B7B7E
62D16BD2 E33F 47DA 8317 1715F970AE52
68184286 5330 4B6D 9569 EF004D5F0C33
0E9F5475 FEBD 4332 8D86 4FF6CAC650D3
92AABB9E 4B47 43A6 A116 1BE86EAAD59D
OK I removed 2 x 4’s all around the sides rough cut the excess off on all four sides then threw back on the machine in the fit is just about perfect I will still have to take material off the sides
It’s still working progress and I still have to do some work
Next I will take it back off the machine spread bid sheet over top of it and put another heavy coat of fiberglass resin on it
I’ll be away for two weeks and I will be posting the final fit and how I’m going to secure to the rollbars
BWAF
BWAF
8,869
42,494
Carthage MO
View attachment 67792 View attachment 67793 View attachment 67794 View attachment 67791 View attachment 67791 View attachment 67790 OK I removed 2 x 4’s all around the sides rough cut the excess off on all four sides then threw back on the machine in the fit is just about perfect I will still have to take material off the sides
Is it getting nice and solid
Dubfab
Dubfab
58
107
Pennsylvania
So I went ahead and put the bed sheet and put another heavy coat of fiberglass resin on this will be my stopping point until I get back home
487F1519 3697 4B29 9CD3 78F726AB56AE
Dubfab
Dubfab
58
107
Pennsylvania
Yes it is definitely stiff but seems flexible and I may resin the bottom-side facing riders with a coat of resin
Or resin in some sort of interior support
Not sure yet I like that one person can move it around easily
But more coatings of resin will only help
Dubfab
Dubfab
58
107
Pennsylvania
OK I’m back home summer things that I did I trim the outside edges sanded the top and putting Undercoating as a top layer
Here’s a picture of it sanded down after I trimmed it up
Reactions: BWAF
Similar threads
