P1000 PK5 won't start, gear position indicator flashing "-", and flashing C----H
T
tvolsr1
Holladay, TN
This is a wonderful site! I've visited it numerous times since getting my PK5 in April, and this is my first time posting. I rarely use low range in my PK5. But I was pulling a small trailer with brush a few days ago. Everything worked fine. I started and stopped it several times, turning it off and on. It did seem a little difficult to get in and out of low range, but otherwise it was perfect as usual. I tried starting it yesterday and nothing! Battery is fully charged, but it made no noise at all. With the ignition in the "ON" position, the gear position indicator was flashing "-" and the temp was flashing "C----H". Mine is a 2020 model. Has anyone had this problem, or have suggestions? THANKS!
1628701247065
1628701350052
Reactions: Lady01 and TxDoc
66,871
Is your check engine light flashing.
Should flash longs and shorts.
How many of each?
Reactions: Lady01
T
tvolsr1
Holladay, TN
How many of each?
Check engine light isn't flashing, it's constantly on. And I'm not sure what you mean by "longs and shorts."
Reactions: Lady01
66,871
If it was flashing.. it would flash long x times and short x times.
This giving us a code.
Reactions: Lady01
T
tvolsr1
Holladay, TN
I assume you are referring to the check engine light flashing. I'm about to head home and I will check again. But I don't recall noticing it flashing yesterday. I will respond in 1.5 hours or so.
Reactions: Lady01
