P1000 Plain and simple pic of dual battery setup
Damian
34
Independence KY
P1 P2
RockRain
RockRain
48
101
UT
Here is what I came up with...
I wanted to create something that had minimal impact on the existing plastics and be adaptable for future mods. I was having a hard to drilling and cutting into the brand new machine! Looking back after chopping the top and all it has been through, it is not that big of deal now.
20180225 174005 20180203 211545 20180225 174049
Rbol121
Rbol121
61
91
Livonia, MI
Man I wish I had the capability to wrap my hear around this. Everytime I read a thread on this , it hurts my brain. So not good at picturing or knowing where to even START. I need wiring for dummies and elementary instructions on how to complete..ugh
Tundra20
Tundra20
316
813
Arkansas
Really pretty easy just wire ur batteries parallel
Which means pos+ to pos+ negative - to negative-
U can also add a battery isolater so ur main battery will not get discharged if u have lights and etc running i dont have a good picture at the moment but the isolater is wired in to either battery u can do it and yes i agree some times hard to tell were all the wires are going in a picture lol
Rbol121
Rbol121
61
91
Livonia, MI
thanks, its more trying to figure out "buss bar", "battery isolators", fuse block, then wiring all accessories to switch and such..heads spinning just thinking about it..lol
Reactions: Trueblood85
Tundra20
Tundra20
316
813
Arkansas
Yes it can be confusing but take ur time there are lots of good videos on the tube but first thing is get ur isolater installed i will get the xact wiring on mine tomorrow and post back and ur accessories are wired to ur second battery and or fuse block figure out if u want accessories to come on with key on or off will be one of ur decisions
Hope this makes sense
Reactions: Rbol121
OnTheJob
OnTheJob
426
925
Bristol, NY
My advice is to wire it ALL at the same time. I added one switch at a time and now I probably have twice as many wires back and forth to the switch panel than needed if I planned it all out ahead of time. I'm (half) tempted to start over from scratch when it gets warmer out. But then why bother if everything is working the way I wanted it. If there is a problem later, it'll be hard to trouble shoot.
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
Still havent got around to cleaning mine up. Maybe someday
Reactions: Bad_bowtie
RockRain
RockRain
48
101
UT
P1000 - Under hood wire management
Read the links in here. Good info to make a system from scratch. It explains relays and how they work, switches, fuse box, buss bars, resources for connectors, switches wires etc. You don't have to go crazy like that but lots of good info.
Tundra20
Tundra20
316
813
Arkansas
DA67C218 CB06 4B10 BB24 39A6DD961B73
As u can see here in the picture two large red wires both come off of the isolater going to each postive post on each battery then run ground from isolater to battery
