P1000 Plain and simple pic of dual battery setup
Gumby
Gumby
49
104
Freedom, WI
Hi All, I'll be hooking up my dual battery and all the fixin's after the first of the year. There are a lot of dual battery posts in this forum but not a lot of pictures. A picture is worth a thousand words, right?
What I'd like in this post is pictures of under the hood of your 1000. I'd like to see spots that we have in common and also what everyone does different. Obviously, the dual battery sits in the recess, but everything else doesn't necessarily have it's own spot.
Let see some pics.
Looking for winch relay, distro block, isolator, wire paths, etc.
Bad_bowtie
Bad_bowtie
Huge member
2,549
15,704
East Tennessee
Biggblu601
11
9
Mississippi
These looks good. Adding myself to this thread for ideas when I start mine.
Reactions: sharp
sharp
sharp
3,757
14,955
Tennessee
Be careful zip tying all your accessory wires together. You could snag a wire on a stick or something and rip out all of your hard work. If you do use the small zip ties pulled just snug and not very many so they will break away and only rip out just the wires that get snagged. I know from experience, luckily the wires broke away.
RiverratTX
40
81
Austin, TX
Let see some pics.
Pretty straight forward. All accessories running through roof controls/switches. MaIn battery runs the stock set up. 20180824 105249 20181103 185321
RiverratTX
40
81
Austin, TX
Let see some pics.
Pretty straight forward. All accessories running through roof controls/switches. MaIn battery runs the stock set up. View attachment 100321 View attachment 100322
Reactions: Plumber32 and sharp
A
Average_Joe
952
3,535
Gainesville, Fl
  2. Other Brand
Does anyone have a photos with a battery under the seat I'm wanting to run a second full size car battery Optima yellow or blue top.
Reactions: Eltobgi and sharp
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Mine is definitely not the prettiest wiring. I currently have an extra blue and yellow wire going to the front to power the hydraulics for my snow plow. Also you'll notice a master shutoff on the left. That kills EVERYTHING on the entire machine. In the back is the solenoid that powers all accessories and next to it is the fuse box that came pre wired. B8b3bfb18ad572fcba250e29e60237ccAdd6b302f2135eefcc12c2bf1226923fA1b912e72d65bb6dc80844e6654fdc2b
69,256
Mine is definitely not the prettiest wiring. I currently have an extra blue and yellow wire going to the front to power the hydraulics for my snow plow. Also you'll notice a master shutoff on the left. That kills EVERYTHING on the entire machine. In the back is the solenoid that powers all accessories and next to it is the fuse box that came pre wired. View attachment 100480View attachment 100481View attachment 100482
That looks more like it! You must of hand applied the dirt in there. Because we know that the l.e. doesn't go Offroad;)
