Hi guys,
Thanks in advanced for the help. I have a 2016 Pioneer 1000-3 that has the aftermarket bench seat in the bed. Every time I have been off-roading with people in the back I have had problems hitting rocks in the back. The shocks are stock and I currently have the stocks 27'' tire on 12'' rims. My problem is that there are a bunch of ways to address the problem and I'm looking for the best way forward. These are the options that I see.
1. Cost: $1,500 Upgrade shocks. Most likely to 814s. I could stiffen up the back and it should raise it up about 2'' (I think...) I think I might need wheel spacers if I went this rout which is another $100
2. Cost: $900 arched A-arms with offsets. This would mostly reduce hitting rocks on the A-Arm. Would also be required for bigger tires/rims.
3. Cost $1,000 new tires and rims. The reason I would need rims is because with the 12'' I can only go up to 27'' tires. If I could go to 29'' tires it would go a long way toward getting everything in the rear higher.
4. Cost $300: Get a 3'' lift kit. I don't know how much this would help because I think I am often hitting the A-arms. If anyone has done this and it has helped a lot I would love to know.
If I wanted to be really prescriptive, I could maybe do rear shocks and rear A-arms. The problem is that 814 shocks are sold as a full set, so I would have to go with OEM load-levelers or Fox.
Anyways, how have you guys addressed this. In a perfect world, I would drop $3,500 and do shocks, A-arms, wheels, and tires, but I don't really want the throw that kind of cash on this right now.
