I think it was the differential trying to engage making the noise as you were already in a bind.
Does your machine still make the noise while on level terrain in and out of 4WD?
@JACKAL Yeah bud it does... If I'm going in a straight line it will make a loud pop here and there. I can't time it. It can be described as the sound it makes when wanting to go to turf to 2wd or 2wd to turf or locking into 4wd but its under strain so the noise is way
mo louder. (Seems as it gets worse as the machine gets warm... The longer I ride, the worse it gets.) After a bit of riding if I go in anything other than a straight line... Its pop, pop, pop, pop, and it's not like axle click it's like feel it in your butt kind of pop. So to clarify you get a pop every once in a while going straight, then if you turn ever so slightly pop, pop, pop.
Same thing with 4wd. I like to haul mine in 4wd lock. Seen that mentioned somewhere once. Seems like if it gets in any sort of bind it makes a loud pop from front diff area. Sound just like a log hitting the center of the floor board. Horrific sound.
I've tried adjusting the cables to spec and in both directions out trying to achieve desired result. The cables aren't a contributing factor to the pop... It's still there. The good news is my display reads correctly for all modes and there isn't any slop in my levers now.
My pioneer is currently getting detailed... Getting the ol' gal ready for the stealership. Man I hate going to them. I feel like they have no clue. Really wish this one could be figured out on my own. Let me know what ya'll think. I'm all ears and really appreciate all the help.
