This Public Service Announcement is brought to you by HondaSxS.com
Do you have a 5mm LONG-ARM allen wrench (hex key) in your trail tool box?
If not you should think about adding one ASAP!
AND HERE's WHY!
Let's say something happened while out on a ride and you needed to access the air box on your Honda Pioneer 1000. Do you have the tools do to so? Normally, almost every air filter on a Honda SxS or ATV could be accessed without tools or just a basic screwdriver. That was until the Pioneer 1000 hit the market.
I am usually a prepared guy and carry enough tools to disassemble my Honda ATV out on the trail. Over the past few years, I have been slowly upgrading my box to fit the needs of my 700 and now my 1000. But today I was stumped in my own garage while trying to disassemble the air box on the Honda Pioneer 1000!
A 5mm long-arm hex key was in need and I couldn't find one to save my life.
I finally survived by using a 3/16 hex bit on a socket. After dropping it a few times I switched to a magnetic screwdriver bit extension. Then I was able to get all the bolts loose for the air box. Setting it back up posed a challenge. I stripped one then a second. Finally, I just decided to lightly tighten them and will just buy a 5mm long-arm hex key for my trail tool box!
I would actually recommend a full long arm set.
Maybe just throw the metric in your trail tool box and leave the standard in your regular tool box.
Here is the one I am looking at! --> TEKTON 25252 26-pc. Long Arm Hex Key Wrench Set, Inch/Metric
I hope someone finds this post useful even though its just a basic note.. lol.
I will be posting info on the air filter inspection soon!
AND HERE's WHY!
