P700 Pulled the load
Diverguy
Diverguy
120
321
PA, USA
This was one of my favorite weekends...time to get the water back on at my cabin! I have a 275 gal. tank that's stationary, and another that's built on it's own trailer. I pump from the trailer to the tank. I pulled the trailer with my Rhino, but was a bit concerned about pulling the heavy load without a low range. Well, my 700-4 did great! There are a few spots where my Rhino bogged down a bit, but the Pioneer didn't even flinch. Pulled that heavy load with ease! 2300 lbs of water, plus the weight of the trailer puts it around 2500 lbs. I only have to go a 1/4 mile or so to fill up, but it's rocky trails to get there. No problem!
Russ989
Russ989
22,573
146,566
The 700 is a very capable machine, glad to hear it’s working for you.
Diverguy
Diverguy
120
321
PA, USA
A509E2B4 191B 491E BE05 70A497CF9B98
This is my tank trailer. I wasn’t looking for a speed demon. Our trails are all very rocky, and run some nasty ones to get to my hunting spot. I wanted reliability, not speed. I was really happy with how easy it pulled the load.
DBOne
DBOne
34
44
Southern Wisconsin
That is awesome.......every time I get into my 700 it seems to impress a bit more. Utilize mine in a similar fashion although haven't pulled anything near that weight yet.
jwfirebird
jwfirebird
927
1,446
western ny
same here, had a rhino too and got this, was more new rhino than the wolverine for sure. impresses me every time I use it. sun I hauled a bunch of branches on old equip trailer probably about 3k through a bunch of mud and little hills. people always down it, say it cant move itself. towing torque is definitely there at least
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
nice. my old cj gets moved around my yard on a 16 ft trailer behind my 700-4. and iv put a crawfish setup on the trailer before and drove it to the lake from the camp about 7 miles with pots crawfish 150 gals of water coolers and such. these machines dont get near the credit they deserve
11,322
84,128
Have the same water tank and 5x12 utility trailer, wanting to fill from creek and pull around a flat pasture track for watering with P500, slow and easy. P500 has a very low 1st gear. Any thoughts?
P500 - P500 pulling 2800 lb trailer in yard
6AAF6236 E555 425F 965E E9486C4F01C4 2B9950DF 3CD7 4A71 AA06 BEB3DEF4AE7B
jwfirebird
jwfirebird
927
1,446
western ny
wouldn't be surprised if it did fine, we have real heavy snow here feet at a time and one of my neighbors plows half his yard with a 500. I would do it so you aren't trying to go over where you sprayed and the trailers tires should be wide as possible or possibly double if you are doing sand or loose dirt, that would give it every advantage.
Reactions: Mudder
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
it will pull it just balance it good so its easy on your suspension
