Deluxe700
Found out one thing real fast; these things are freaking heavy! And don't turn around in the front yard! That inside rear tire will tear some stuff up. Luckily I saw the probable outcome while I was in the pasture.
The rule is Max weight doubled for a winch, which works out to that 4500-5000 lb range I mentioned. You could maybe use a 2500 with a snatch block, but you lose range in the rope.Yeah. I am not a mudder either, even though it is really popular here in the south. I live in the Blue Ridge here in Georgia, and our trails are mostly rocky and hilly terrain, so getting high centered would be my main concern.
Define a "cheap" winch. I am thinking a good quality2500lb Warn would do the trick ( I had one on a 500 Arctic Cat a few years ago and it was solid)
Harbor Freight huh...I had a little trailer from them that was awesome. I will look into their winches. It isn't like I would be using it a whole lot anyway. First things first though; windshield. That's another thing I realized pretty fast that I will need.The rule is Max weight doubled for a winch, which works out to that 4500-5000 lb range I mentioned. You could maybe use a 2500 with a snatch block, but you lose range in the rope.
Warn certainly is the big name in Winches, but I'd have no issue with a Badlands brand from Harbor Freight. I used a cheap Champion on special from Tractor supply and had no issues. I think I had 180 total In the winch and the mount.
And always someone there to egg it on @Backwoods....When it comes to accessories every time you say your done it seems like some other have to have comes along
Welcome to the forum Noob! Yep, no turf mode on the 700-2, gotta watch the lawns and gravel driveways. Talk to your banker and set up a line of credit for your mods...And don't turn around in the front yard! That inside rear tire will tear some stuff up.
I don't want to be the only one whose wife gets pissy about all the must have items.And always someone there to egg it on @Backwoods....
Lmao, you got a point there brother....I don't want to be the only one whose wife gets pissy about all the must have items.
Guess the club is growing by one member......!Lmao, you got a point there brother....
IMO, you won’t be happy with a 6-10” light bar for a front light.Already shopping for light bars...thinking maybe a 6" to a 10" and maybe a couple of 4" square pods as back up lights. Just put a roof on.
OK. I'm all ears my friend. Remember my handle is "noob"
