P500 Put Battery under the hood
slow poke
7
pike county ky
placed a battery box under the hood. bought a 12 v. lawn mower battery,
ran whip lights off the battery, horn off the single battery, turn signals too!
but must re charge when back home. has it own power supply,
just in case a power failure out in the woods, i have an extra battery to boost off hopefully
so far no problem
just recharge after I get back home your thoughts?
I forgot even the wench and fog lights too dont know how long the battery will last mainly for a back up
thought id try it any way
Reactions: duhmojo
duhmojo
duhmojo
32
45
Canada
Pics of how you secured the battery under the hood?
I know there's a backup/dual battery mod that uses the TRUE cut over kit: TrueAm UTV-SBI-18CM UTV Dual Battery Isolator Kit
I have no experience with it, but the alternator should help keep it charged, and you'll have a much higher capacity from a single battery wiring setup. Plus the voltage meter will show both batteries so you know if you even need to charge.
I'm sure others with this mod will chime in.
  • Love
Reactions: slow poke
178,298
so far no problem
You have the right idea, just need to wire it in. Two good size cables between the two batteries and you'll be wired in parallel which basically makes them one big battery. Ran a Die Hard lawn mower battery with the stocker for 5 yrs that way. Mine was under the seat though.
slow poke
7
pike county ky
understood I see where others having shifting problems with voltage issues, so thought id try it so far so good thanks for the input
slow poke
7
pike county ky
yes understood thought about it . but a friend of mine said its risky i not sure , but really mostly just in case me and the wife gets out and the battery go's dead have a way of starting back up
was the orginal plan, and having an extra battery for a boost if needed but started adding the extras on the back up battery
I seen the kits but not sure if i want to go that way
may put too much stress on the stator? maybe? thanks for the reply love my p 500.
slow poke
7
pike county ky
yes understood thought about it . but a friend of mine said its risky i not sure , but really mostely just in case me and the wife gets out and the battery go's dead have a way of starting back up
was the orginal plan, .
I dont have a way of taking picture I tell you it work's great though strapped the box to the cross member and placed the battery in it secured it with sponge on the sides and so far so good lol
178,298
slow poke
7
pike county ky
Just wondering folks when going down a hill using the brakes in low gear, there a clanking noise from the back
I changed the pads and that not a problem every thing tight
but on the normal ride no issues just in riding the brakes on a down ward hill just wondering?
Mudder
Mudder
NTC Ambassador of Walls
11,650
87,937
A simple alternative for peace of mind.
DEFFCE1C BC18 4CD3 91B6 44F57A626ED6
178,298
It's gear clatter, they all do it.
Reactions: Bmurray
