P1000 Question do you have a winch with the honda bumper
ofrcboy
ofrcboy
507
589
Oregon
Question for owners with the stock Honda front bumper and winch with the Honda or KFI winch mount.
1. How hard is it to reach the free spool knob on the end of the winch to place in or out of gear?
2. Can you see drum good enough to see how the rope is winding on the drum when winching?
Please be serious, I am very interested in your answers as on my old Big Red it was very hard to reach around and behind bumper to turn knob and see the rope. Thank You
66,870
I hope to have details soon. Waiting my OEM bumper to arrive. Then install begins.
Even if you could access it, it would most likely be under mud because of its low location.
T
TimL
12
9
I installed the KFI plate and winch on the 1000-5 stock bumper. The free spool knob can be reached without difficulty but with the fairlead mounted it makes it difficult to see the wire/rope drum.
ofrcboy
ofrcboy
507
589
Oregon
Thanks for the reply, that is the information I need.
ghost
ghost
993
1,873
BC
So ofrcboy - are you mounting there or do you have another option?
ofrcboy
ofrcboy
507
589
Oregon
I think I will be waiting for the EMP winch bumper. I have had two of these, they are well built and the winch is mounted on top in plain sight. I see a couple other vendors working on winch bumpers so that could be another option for me also. I have some time as I am waiting for my Phantom Camo 1000-5 but Dealer says every day we are 1 day closer. GRRRR!
educ8tedguess
educ8tedguess
403
972
Spring Grove Illinois
  1. Looking to buy
I too mounted the winch with the KFI mount. The free spool dial is tougher to get to than my previous machines but it is also better protected. Now, this is my opinion as it sits in my garage. When I think about accessing it when stuck, it seems quite a bit more difficult because you can really only access the dial from one angle.
The spool is hard to see. This I do not like. I too will be going with an aftermarket winch bumper when they are available.
Reactions: ofrcboy
ofrcboy
ofrcboy
507
589
Oregon
The spool is hard to see. This I do not like. I too will be going with an aftermarket winch bumper when they are available.[/QUOTE]
Thanks for your review.
educ8tedguess
educ8tedguess
403
972
  1. Looking to buy
Thanks for your review.[/QUOTE]
No problem at all. Something to think about... I'm not sure how long it will be until someone makes a good bumper for the 1000. Strongmade said they are close and EMP said early 2016. If you plan on needing a winch soon, the install of the KFI mount takes very little time and is pretty cost friendly. It will hold you over until you can pick up a bumper if that is the route you will go. But make sure you don't shorten your winch wires or switch wires if you plan to make a change. I only say this as I have made that mistake.
ofrcboy
ofrcboy
507
589
Oregon
No problem at all. Something to think about... I'm not sure how long it will be until someone makes a good bumper for the 1000. Strongmade said they are close and EMP said early 2016. If you plan on needing a winch soon, the install of the KFI mount takes very little time and is pretty cost friendly. It will hold you over until you can pick up a bumper if that is the route you will go. But make sure you don't shorten your winch wires or switch wires if you plan to make a change. I only say this as I have made that mistake.[/QUOTE]
I am still waiting for my machine as of now so am hoping a bumper is available soon.
rocmar
rocmar
4,741
5,776
4 CORNERS
I got bumper & winch
No problem at all
