Radio wiring help
K
Kolton
117
82
Vance, al
I bought a boss radio with 240 watts output over 4 60 watt channels. I do not intend to use an amp only the power provided by the radio. My question is if I only have 2 speakers to power can I bridge the channels together like you can on an amplifier? If so ....how ?(see pic) Ee412605444371052c44a6e8b88793f8
Hondoman
Hondoman
727
1,697
Texas
I bought a boss radio with 240 watts output over 4 60 watt channels. I do not intend to use an amp only the power provided by the radio. My question is if I only have 2 speakers to power can I bridge the channels together like you can on an amplifier? If so ....how ?(see pic)View attachment 54480
By looking at that schematic, I'd say you can't bridge it. Is that the only diagram there Is? Normally if bridgeable there will be multiple schematics.
Reactions: ohanacreek
K
Kolton
117
82
Vance, al
That's the only diagram it can with. Which 2 wires should I use to hook to the speakers? I've never wired speakers up before, I appreciate any help you can give me.
swsebek
swsebek
2,854
5,835
pa
I wouldn't bridge a radio period.
If you do you will smell it
If that radio is Bridgeable it will say so....
Some older pioneer radios you could and power a sub woofer a little.
But most smoked
Hondoman
Hondoman
727
1,697
Texas
I'd hook up to the front left and right, make sure your positive and negative match. Usually the negative side of the speaker wire has a black stripe. Positive may be indicated with a red dot on the speaker itself.
Reactions: Kolton
K
Kolton
117
82
Vance, al
I appreciate the help very much guys
A
Average_Joe
951
3,534
Gainesville, Fl
  2. Other Brand
I wouldn't bridge it but the instructions are pretty straight forward it tells you what colors to use for positive and negative speaker hook up at each channel
knuckledeep
knuckledeep
my trailer queen is trashy
1,052
3,470
Eustis florida
marine head units you cant mine came with a small amp and it sounds good
