Mom is doing the same thing stuck on full that's greatWell that's great to hear.. I've had mine for about two weeks and I've only had it out once.. I rode about twenty miles and the gas gauge was still on full when we got back to the truck. I thought there was something wrong with it.. lol
Hope your Mom is too . LOLSpell check on my phone is crazy I meant to say my Talon is doing the same thing showing full all the time
Would think the RZR would have done much better as I know in that many miles you had to tow it at least half way .we just did a 780 mile loop with ours loaded with camp gear 6 days and 5 nights all different terrain and speeds and got 29 mpg our friends rzr 1000 got 24
This sounds right to me ( i assume the 1/4 was intended to be 14) i removed the tube in the fill neck, when on a ride that i know to be 140-150 miles i dont take the rotopax. Known rides over 150 miles i take a 2 1/2 gallon, known rides around 200 plus gets the 4 1/2 unexplored areas that i guess at 175 or more i take the 4 1/2. I take both at 175 plus when there is someone along who doesn't carry fuel. Dont care about the fuel mileage, i just fill up when i get back. Glad the holiday weekend is over and a lot of people went home, we will probably do 200 plus wednesdayMy usual day ride area is smooth gravel trails and I get 17-19 but when I hit the rocks, it drops to 12-1/4.
17-19
12-1/4
For the record, I can see where you'd think 12-14 but I shortened the 12.28 to 12-1/4. Saying 12.28 seemed a bit OCD. 😊 I only had a few rocky rides this summer and they were all in the 12 plus a little bit, that one stuck in my head.This sounds right to me ( i assume the 1/4 was intended to be 14) i removed the tube in the fill neck, when on a ride that i know to be 140-150 miles i dont take the rotopax. Known rides over 150 miles i take a 2 1/2 gallon, known rides around 200 plus gets the 4 1/2 unexplored areas that i guess at 175 or more i take the 4 1/2. I take both at 175 plus when there is someone along who doesn't carry fuel. Dont care about the fuel mileage, i just fill up when i get back. Glad the holiday weekend is over and a lot of people went home, we will probably do 200 plus wednesday
I am running 32's and i don't think they were a good choice. I do believe that the fuel range decreased significantly when i went from 30's to 32's, but like CID i believe the mileage is wildly variable and so i only concern myself with the range130-140 miles with stock wheels and tires.
If you get tired of the snow in the denverish area and come on over to southwest utah there is lots of desert to explore. Our ride last thursday was 137.04 miles with a moving time of 6.20.09 hours for a moving average of approximately 21.632771 mph. I think i kind of understand ocd😁For the record, I can see where you'd think 12-14 but I shortened the 12.28 to 12-1/4. Saying 12.28 seemed a bit OCD. 😊 I only had a few rocky rides this summer and they were all in the 12 plus a little bit, that one stuck in my head.
Like you, I don't care (much) about gas mileage but, wanting to explore the desert, I care a whole damn bunch about fuel range. Knowing it's so wildly variable isn't very comforting, how far can I really go today? I've also removed the tube in the fuel fill neck and bought a 3 gallon RotoPax for exploring. The stock tank holds 8.612 gallons with that tube removed, plus the 3 RotoPax puts me at 11.612 gallons times 12 mpg (minimum?) gets me 139 miles, that's a pretty long day and probably impossible in 12 mpg terrain.
What is the tube in the fuel filler neck and how to remove it - (at your own risk, Dudes)
(1) NEW BIGGER GAS TANK - The Honda Side by Side Club! (hondasxs.com)
My brotha!!If you get tired of the snow in the denverish area and come on over to southwest utah there is lots of desert to explore. Our ride last thursday was 137.04 miles with a moving time of 6.20.09 hours for a moving average of approximately 21.632771 mph. I think i kind of understand ocd😁
I've seen these MPG questions before and wonder if their mileage is based on the odometer or a GPS reading. Do people realize when they put larger tires on, they are actually going farther than the odometer reads? Some vehicles have odometer correction methods. No idea if the Talon does.I am running 32's and i don't think they were a good choice. I do believe that the fuel range decreased significantly when i went from 30's to 32's, but like CID i believe the mileage is wildly variable and so i only concern myself with the range
Speedo DRD makes a mileage correction device for Hondas, one of them will work on the Talon. But there are 3 speed sensors on the Talon, I'm unsure what happens between using one or three, both choices are options depending on your setup. I can't add more info, I haven't looked into it.I've seen these MPG questions before and wonder if their mileage is based on the odometer or a GPS reading. Do people realize when they put larger tires on, they are actually going farther than the odometer reads? Some vehicles have odometer correction methods. No idea if the Talon does.
