ok, I thought I would start with the knowledge base here first;.
New owner of a (new) 2018 P1000LE. When shifting from turf to 2wd to 4wd the dif lock light does not come on. Yesterday I went out to a wet section of the pasture and in turf mode I lit the tires up and left two distinct track marks (I thought there should only be 1?), then I went into 2WD and then 4. In two wheel drive i left the same tire tracks. in 4wd there were no tracks indicating all 4 tires pulling together. My main question is that are the indicator lights controlled by an internal switch or from the actuating arm. Is this anything I can look at? The dealer I bought this from a week ago is a 5 hour drive away so anything I can do locally is the best bet.
