P1000 Rattles and squeaks
RJB
20
Durango, Colorado
I know rattles and squeaks are just part of the UTV world but what are you guys doing to keep it at bay? The main culprits seem to be the doors and the dump bed. I have wrapped the latch bars with electrical tape and this really helps but it only lasts for about 60 miles until the latch wears through. Has anyone come up with a more permanent fix? Also I have been getting some very obnoxious deep squeaking from the roll cage. Will tightening up the bolts help this.
I just love how quiet this machine runs and the rattles are way more noticable because of how quiet it is.
N
Nightcrawler
103
229
Portland, OR
It can't hurt to re-torque the roll cage bolts and see if that helps. I adjusted my bed latches down so they hold the bed tight, that seemed to get rid of the noise as well. You have to fool with it a little bit and make sure you don't go too far down, or the bed will be hard to dump. I put tape on the door latches as well, but I think there is room on the hinge to slide a washer in there and tighten up the gap as well.
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
Some people put a good stereo system so they don't hear it and add some grease to your tape
Upstatefreedom
Upstatefreedom
224
410
Colton,New york
The doors do have adjustable rubber stops. All you have to do is turn them out a little and it will tighten the door. Don't go to far or it gets hard to close. I also had to move my door catch on the ROPS down a little to put a little more pressure on the latch. I noticed the passenger door was actually moving up and down at the latch end a bit on reall rough roads. As for the box Nightcrawler is right, you can fiddle with the box latches but it can get tricky. Lol.
Reactions: Luv4Chaos1
RJB
20
Durango, Colorado
I actually put a rubber bumper extension on the rubber stop and adjusted the doors and latches as much as possible. They still rattle unless I have fresh tape (chanded out every ride if I want to stay quiet). There has to be some type of permanent material that you can put on the latch catch bar to stop the metal on metal contact. Anyone have any idieas? I will try adjusting the catches on the dump bed as well.
franzw
franzw
277
249
pacific nothwest
Has anyone had trouble with rear side windows not aligning properly to latch closing? I have the 1000 deluxe with hard roof. Have taken it to dealer to adjust, just didn't take. Real pain, any ideas? Getting ready to go after it with hammer and wrench.
Upstatefreedom
Upstatefreedom
224
410
Colton,New york
Huh. If I turn my rubber stoppers put any further the door won't close. Surprised you had to add extensions to yours RJB.
vince
vince
155
293
vidor texas
i drilled a small hole in clamp and rops. small screw no more hinge twist.helps alining for putting back on after summer.
Reactions: franzw
franzw
franzw
277
249
pacific nothwest
Thanks will try that next. Need to align them before hunting this fall.
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
On the dump bed on the metal bar where the bed hook's at top and bottom I wrapped it with rubber and zip-tied it on there and that keeps the bed from rattling.
