Ours are made in Tempe, Az in our machine shop. others are from a mold, or pre-cut, ours are 6061 Aluminum, we also made the 1 1/2 and 2" we ultra- light. I will post a pic of that as well. You ask anyone on this forum who has RB3 spacers there is a difference - better quality, nice looking and we are part of the group. I stand 100% behind any of our products, hardware included as well!Seriously considering these. Couple questions.
Do you have a pic of a pioneer with stock tires with these to show how different it looks?
Are these made in the US?
And lastly, I noticed that your spacers cost a bit more than some others on the market, is there a difference in material, construction, etc. to give an advantage to yours over others?
Thank you
1.5 all around is a nice set up - $219.00 plus shipping or the extra wide package which we have alot of people who like that is 229.00. The discount for the guys on the forum is 10.00 off any orders over 120.00 use code taketenWhat size do you recommend? 1.5” all around?
And how much is a set of 4 with the forum discount and whatnot?
our Wide Track bundle would be great for your set up. That is 1" in front and 1.5 in back. it will add stability help with widening your stance and help from rubbing.I have a 2018 1000-5
I’m installing 1.5” forward arms and 30” rubber with Elka stage 4 shocks all around. I’m undecided on replacing my factory deluxe wheels or not. Can you explain the benefit of wheel spacers and what you would recommend for my setup if needed.
The rear track width is narrower with the same offset wheels. Takes almost 1" more on each side wheel spacer to even out the width front to rear with the same wheels on both.I will be going with aftermarket 5+2 rims 14x7 on all 4 corners
If I purchase your wide track bundle how will it track. Is it normal to be wider on the back end or should the stance be the same front to back? With the forward A Arms I am assuming I will lose some width on the front end.
Sorry for all the questions, I want to get the setup right the first time.
yes it will work because as they said its narrower in the back so 1in on front 1.5 in back works greatI will be going with aftermarket 5+2 rims 14x7 on all 4 corners
How do I get these ordered, I would like to get a full set of spacers front and back.
Honda Pioneer 1000 Wide Track BundleHow do I get these ordered, I would like to get a full set of spacers front and back.
Im from canada, I can call tomorrow and see if the shipping and duty will be worth the hassle...
Sounds good - 480-389-7486Im from canada, I can call tomorrow and see if the shipping and duty will be worth the hassle...
