P500 Rear brake pads
  • Thread starter ValleyAdventureTours
  • Start date
V
21
Can
I am replacing rear brake pads and the aftermarket pads do not have the tip that lines up with the caliper piston or the metal plate and fiber pad that sits between the pad and the caliper piston. Will using these pads cause a problem?
Thanks in advance!
15632957334391568237600132722878
Reactions: rtn001
Mudder
Mudder
NTC Ambassador of Walls
11,656
88,014
Running some aftermarket rear brass pads with no caliper groove tip. I did reinstall the plates. No problems. Trying out brass due to frequent muddy conditions.
V
21
Can
Great! Thanks for the peace of mind!
Reactions: Mudder
William
William
1,442
2,887
Flowood MS
No it doesn’t matter... race driven pads come with the backing plates though...
