P700 rear brakes bind up after 10 minutes of riding
snookpro
17
24
I have 2014 700-2. The rear brakes start binding up after 10 minutes of riding. I replaced the brake pads and still continued to bind up. I then replaced the master cylinder and rear rotor. I bled the brakes making sure no air in lines. Worked ok first couple of rides . Now it's doing the same thing. The brake pedal gets tight and I have to go to the bleeder valve to release the pressure. I can then go for another 10 to 15 minutes before they begin to lock up again. Anyone had the same problem or have any ideas.
5,024
22,433
Have you cleaned and greased the caliper pins, they have to slide freely so the pads can retract 'a bit'. If not, they'll drag, heat up the fluid and squeeze the brakes.
snookpro
17
24
Failed to mention that i also replaced the caliper.
Reactions: Smitty335 and CID
snookpro
17
24
Sometimes the rubber hose collapses a bit and acts like a check valve. Usually on older stuff, but worth a shot.
I will check that out. What's odd is my hunting buddy has a 2018 Pioneer 500 and his front brakes started doing the same thing. at about the same time. He just drained his brake fluid and ended his problem. Doesn't have any brakes but they don't stick now. I prefer to have brakes. Thanks
41,749
Yeah...brakes are kinda nice sometimes.
41,749
Oh...and please let us know what the fix is.
So many people ask questions and never come back or tell us what fixed this or that. Following up really helps the poor sucker down the road with the same issue.
1950Willys
1950Willys
71
151
Arkansas
My 2014 also had rear brake issues over the weekend. Riding Buckhorn trails in NW Arkansas and about 9 miles into a 23 mile ride the brakes started sounding like pure metal to metal contact. It sounded like front left brake grinding and at the time was more concerned of getting it back to trailer than trail fix. It made the noise several times when brakes were not being applied so I was thinking major issues. Once home and washed off I drove on street and only when brake pressed did it grind. Sounds were coming from rear. I checked rear rotor and it was freshly gouged. I searched forum and found video from Youtube called "hillclimb and rear braking noise. It was exactly what I was hearing except mine sounded much louder but that may have been the 45 degree headed down a mountainside scared feeling. My question is how do you get the rear brake rotor off? I downloaded shop manual but it doesn't cover rotor removal only brake pad replace. Do you have to remove rear diff enough to get it off or does driveshaft slide somehow?
IMG 4062 IMG 4063
Mudwing
Mudwing
36,959
306,563
The Mud holes
View attachment 263765 View attachment 263766
I’m not sure but I think you are correct. Pull the rear final drive and then the drive shaft should pull out. The rotor bolts to the shaft. 😎
