Does this look like too much positive camber? Super ATV offset arms and lift. They are adjustable but man I am lazy. I thought SATV arms came pre adjusted. FYI I bought used.
Yes. Instructions say 1 to 2 degrees of negative camber is recommended. They don't come pre adjusted. Instructions tell you how to set them to get close. What kind of lift you install?
Save your money with Honda Pioneer 1000 High Clearance 1.5" Offset Rear A-Arms from SuperATV! Get 2" of ground clearance without paying for a lift kit.
I set mine up with positive camber when it's completely empty. When I load all my junk up in the bed, it evens out. Maybe that's how the guy you got it from set it up.
