A couple years ago the PSA on raising venting came out: Multi - PSA - Fuel tank breather hose - IMPORTANT modification for ALL! and the idea of using a bellows off a Polaris side by side for the differentials came up . I ordered it, and got it installed but was never happy with the installation as the nipple was smaller than the bellows diameter, and I had to use a hose clamp to cinch it down, but it wasn't great seal. After my last ride, while cleaning I noticed the bellows had torn at the base and decided to come up with a better solution that I'd been thinking about for a while.
This afternoon I prototyped up the solution. I need to adjust the dimensions a bit to accommodate o-rings to seal it up, and to get the set screw in a better location on the nipple, but the concept is solid and I'm going to proceed. This gets the bellows out of the way of the brake rotor and frame, and is the correct dimension for the bellows and the correct dimension for the vent so everything seals well and will be water-tight.
Here's a pic of it mocked up and installed tonight.
