Need to change the rear pinion seal on my PK1000 -3 Just wondering if anyone has done one on there machine. Is it possible to do this by just unbolting the diff and sliding it back far enough to seperate the drive shaft from the diff and then do the seal change . Or do I have to pull both rear axles out in order to slide the diff back far enough. I'am not close to the machine right now to take a good look at what needs to be done.
TIA
TIA
