P700 Rear seatbelts
L
lylejoshua2020
5
5
Athens
Does anyone know if you can get a seatbelt for the rear seats on the 700-4 without having rear roll cage? It has 2 females on each seat I would need a double male belt. Thanks.
Reactions: Russ989
Russ989
Russ989
22,560
146,466
The only way I know to do that is to remove the belt for the housing and then cut it off with enough length to have some slack and then you’ll have to fold the cut end of the belt a see it together to hold your belt latch key. Also find an adjuster so that the belt could actually be tightened. You may be able to find the size of the latch and order something like that as well. Keep in mind that is a horrible idea to have passengers in the rear of the machine without a cage unless you’re 100% positive you’re not going to flip or flop.
Russ989
Russ989
22,560
146,466
Just saw that your new, welcome to the club. 😉
L
lylejoshua2020
5
5
Athens
Yeah I won’t be doing any crazy climbing at all just using for hunting maybe light trail but no steep climbing. I was hoping maybe you could get some sort of male to make out there somewhere. Thanks for the idea man.
Reactions: Russ989
Russ989
Russ989
22,560
146,466
You’re welcome, I’m sure that some company out there makes something that you could order but I just haven’t seen it or know where to look. I’ll tag one of the 700 experts and see what they can add. @Alan_Vander
L
lylejoshua2020
5
5
Athens
Thank you
Reactions: Russ989
Russ989
Russ989
22,560
146,466
Thank you just bought it two weeks ago so far I love it.
They are great machines, I miss mine sometimes.
9310F7BB A13D 491C B0F5 4A73B929AB56
6FCA4731 15BB 4570 87A0 6A4E038F07E7
Reactions: lylejoshua2020
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
Check up on a jeep rear seat belt. I believe old Cherokee. You can unbolt 1 side and just have a regular lap belt
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
Or the old cj5 andcj7 seat belts youll probably have to change both peices per seat
L
lylejoshua2020
5
5
Athens
