P1000 Rear view Mirror
HivoltageHonda
HivoltageHonda
374
367
Hernando, MS
Looking to see which rear view mirrors you guys are running? Since I have my wet sounds on the middle bar I might need a mirror that maybe adjust?!
273,577
Reactions: joeymt33
I'm also using the Bad Dawg. And, I will be mounting a WetSounds speaker. I'll let you know how it goes.
Justin7372
Justin7372
9
Image Image Im using a wet sounds bar mounted on the front bar and i just mounted the mirror on the bottom of the sound bar. There is a slot on the bottom of the aluminum housing. The mirror is an Axia alloys 9"
Reactions: Jpratt2
322,675
I went with a backup camera with a 7 in display. A couple reasons I went this direction. You can see better at night with or without backup lights. You can see way lower with a larger field of view but the largest reason is no obstructed veiw-it doesn't matter if people are sitting in back or a load of wood in the bed. It's mounted directly straight in front of you on the roll bar very convenient. Might not be for everyone but works great for us
G
geochem66
Pa
View attachment 8593 View attachment 8594 Im using a wet sounds bar mounted on the front bar and i just mounted the mirror on the bottom of the sound bar. There is a slot on the bottom of the aluminum housing. The mirror is an Axia alloys 9"
I really like your Stealth/Axia rear view mirror set up. Where did you get the block/hardware that fit into the Stealth slot to allow the axia to be mounted? Thanks.
A
aurora_pioneer
15
17
Aurora, IN
Now that there is AWESOME! I have banged my muffler several times trying to hook up the hitch...
Reactions: CumminsPusher
1BadDart
1BadDart
1,437
13,308
W. KY
How clear is it?
322,675
How clear is it?
Clear enough. The regular mirror vibrates a little so I’d say probably clearer then that. Only bad thing is things are smaller because there’s more view
1BadDart
1BadDart
1,437
13,308
W. KY
Thank you sir. I need a mirror and like the idea or the camera.
