P1000 Rear wheels alignment issue?
Jaredgriffin29
Jaredgriffin29
34
26
Sandrock, Alabama
What's going on here ?
20210620 105527 20210620 105556 20210620 105533
Reactions: Lady01 and TripleB
115,304
Its called “stock A arms” the camber is commonly “fixed inward” no adjustment.
The only way to fix that is to change your arms like to dome SATV arms for example, you can then adjust them to your liking. Also your stock shocks dont help it either. How long have you had this machine and just now noticing that? Lol
115,304
☝️ ☝️☝️What he said!
could b another probable cause on top of the camber issue. They look
More camber in the pics. Try taking a pic further away and get both wheels in the pic more even.
Jaredgriffin29
Jaredgriffin29
34
26
Sandrock, Alabama
This a better view? So has it always been this way and I just haven't noticed it ? I rotated my front wheels to the back . That's when I noticed it . That's all I know . Lol
20210620 105544
Reactions: pct and Lady01
slowdryrider
slowdryrider
572
778
Canada
When you say rotate front to rear , are you running all 4 same size tires ??
Reactions: Lady01
208,725
Yep! I would check all bearings, A-arm bushings and replace what's worn out, then do your self a favor and replace the stock shocks with the right weight springs for passengers, accessories and what you normally carry in the bed, it's normal even with SATV to have some camber in at the top, that's how they recommend setting up there A-arms, setting spring sag is another deal.
Sjc3081
Sjc3081
263
442
Wappinger NY
Let me be clear. It is the way the suspension is designed. Your rear shocks are auto leveling. When the machine is parked, the the shocks settle.
