P500 Recovery points?
Zaleski
Zaleski
67
176
So, since i'll be using a comealong as my recovery tool i'm wondering if anyone knows what Honda recommends for recovery points front and back? I didnt see anything in the manual about it. It did recommend the front bumper and the rear upright portion of the frame for strapping down to transport.
I'm leary because I had on '07 King quad that got the frame tweaked from pulling out of the mud by the bumper, any imput is appreciated!
Reactions: rtn001
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
iv always just used a raised ball on the rear and the winch up front but i have tied into the bumper a few times with my 700. i went around the whole bumper and didnt choke the line. basketed it 31e134164d8ba368fa170db71d2232e0
Zaleski
Zaleski
67
176
Reactions: rtn001
11,321
84,117
EC911ECC C2AA 477B 8AD3 B387E05C1B11
I was thinking about buying that, or getting the moose 2"reciever, since I already have all the 2" equipment for my truck. Not sure which route to go
Added the Moose 2 in. for pulling heavy trailer (2800 lbs) later on, and it still allows use of the 1 1/4 hitch if needed. Like the higher position of the Moose for a better hill/rock climbing departure angle if the hitch is left installed. It is very thick metal with 2 handy chain hook holes. Recommended and easy installation.
Reactions: rtn001 and Zaleski
208,013
Added the Moose 2 in. for pulling heavy trailer (2800 lbs) later on, and it still allows use of the 1 1/4 hitch if needed. Like the higher position of the Moose for a better hill/rock climbing departure angle.
Good way to bend the rear frame dropping off rock ledges trail riding, been there done that!
Reactions: Mudder and rtn001
56,731
Harbor freight flush and strong , straight pull on the frame , plus cheep !!
I have the same one on my P1k, but I drilled out the hole to take a 3/4" shackle. It's been used numerous times with no issue.
Reactions: Zaleski
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
not a big fan of those shackle mounts. takes too much to hook up when under water. rather just a ball and toss a strap over it. that and i busted one on my jeep years ago. the shackle held past the weld.
Reactions: Zaleski
11,321
84,117
Also have a 2 in. hook hitch that was trail handy for pulls. Used a single strap for the rear going over the hook for tie down.
2B9D74F2 BF40 42F1 90EC 677A326BC378
bowhunterbill
bowhunterbill
413
1,271
Bozeman, MT
I’ve looked and can’t find a hook hitch for a 1 1/4” mount to avoid using a 1 1/4” to 2” adapter protruding rear 8”.
NTCPrezJB
NTCPrezJB
President of #NTC
100,729
899,302
Canton, OH
I bought something from amazon. Let me go check my history and see if I can get you a link.
NTCPrezJB
NTCPrezJB
President of #NTC
100,729
899,302
Canton, OH
924D0B48 CA48 48F4 AF81 96D0E2063E2E
There are several other options. I bought this one so I can have a clevis or pin and still leave the ball. I realize it isn’t a hook but it could serve your purpose.
A different option I considered at the time...
9C88CE5F BD2A 4288 9F5F B2FF7E2EB61D
11,321
84,117
The 2 in Moose hitch was a good purchase, no worries on bending frame, more hitch options, no regrets.
futzin
futzin
3,164
22,757
Kentucky
I forget, does this work with the Honda rear bumper? I read the thread, but can't remember. I can look for it when I have more time, no biggie.
futzin
futzin
3,164
22,757
Kentucky
was thinking there were attachment point issues, different bolts needed. thanks for the link!
Thanks to @ToddH for the fix and the pic!
9rke7vnutag 9hskidlq3a jpg
Reactions: trigger and Mudder
70Bones
70Bones
888
3,779
New Brunswick Canada
Get a hook and a hitch insert, take to your local welder/welding shop. They will make exactly what you want!
bowhunterbill
bowhunterbill
413
1,271
Bozeman, MT
Good advice. I bought the hook at Harbor Freight (probably cast in an unheated factory in the Chinese mountains by slave labor in a re-education ‘camp’.
Looked at it, turned it sideways, bought a few washers as spacers, did a little grinding on a bolt head to fit the 1 1/4” square tube. Duct tape to hold together when assembling.
Just what I wanted- hook close tothe frame for under $10.
092d09073e560ac429415bac0124293c
01fce0bf7633a09d307113bfb71f671c
9b53322cbdb12820b5bf204f659232f1
4b78c46cffa5ef2f5e832b86be92d7c9
