V
Hi guys
I need a little help. I need to replace the rear brake rotor as it has become warped and vibrates badly when applying the brakes. Just wondering if anyone has done this and if I could get some advise on the process. I have been as far as getting the back caliper off and pads removed and would like some advise before I go any further. From what I can see I need to remove the rear axles and diff to be able to change the rotor. I'm just not sure what I am going to get into once I go to remove the diff. Are there any special tools needed or seals that should be replaced at the same time. Does the drive shaft just pull out of the diff once I have the mounting bolts removed. Any advise would be most appreciated. I have a service manual on the way but need to get this up and going asap.
Thanks
Thanks
