Right Stock rim rubbing on the A Arm
tman2th
tman2th
50
172
Green River, Wy
So the right stock Rim is rubbing on the little tab that is welded on the a arm. Anyone know why. The left side clears just fine and doesn't even get close. Just a heads up, I have no idea what I am looking at so if I get some terminology wrong I apologize and am totally up for learning! TIA
IMG 3346
  • Wow
Reactions: CID and TripleB
207,989
Is your tie rod bent?
207,989
Not that I can tell. Is the tie rod what makes the wheels turn and connects to the steering box?
Yes, Is the alignment off? Take a frontal picture and post please.
Reactions: tman2th
207,989
Also measured from the center of the front of the tires across and the back and they are equal distances.
Pictures are deceiving from my end, but looks like the right side tire is scrubbing on the inside of the tread. Just because the centers measure the same, doesn't mean it's not out of alinement. Can you take it to an alignment shop?
Reactions: tman2th
tman2th
tman2th
50
172
Green River, Wy
Yeah, I will take it to a shop and see what they say.
PaulF
PaulF
1,462
4,810
Your rack is not centered. It is a common assembly mistake.on the Talon.
Reactions: TripleB and tman2th
5,052
22,652
Your rack is not centered. It is a common assembly mistake on the Talon.
How do I fix that?
Paul explains it here - page 6, post 117. Oops, there he is now. 😊
Reactions: tman2th
