P1000 Road some really dusty trails last night with some ATVs, how to wash this thing??
Deer-hunter
Deer-hunter
136
200
Effie,Louisiana
I have not use super clean on my pioneer yet. It I used it a lot on my 02 rubicon. You get the biggest off and you always have that muddy film on the frame. I've sprayed it on pure and hose it off. Takes all the film off what ever you spray it on.
Reactions: joeymt33
Mix it 50/50 with water before applying to make sure it doesn't discolor anything.
You MUST spray off the chunky stuff first. You can use it at full strength or near full strength but you will run the risk of discoloring something. The only time I've ever discolored something was the grill of a truck several years ago. I have occasionally used it full strength on the pioneer and have not discolored anything yet. But to be safe so I don't make any enemies, I will only recommended it 50/50. Anything above that, use at your own risk.
Put it in a pump up sprayer and mist your whole vehicle with it. Let it sit for about a minute with (out drying) and then rinse it off.
Wondering about a potential different use for this product. Any idea if it's safe/effective on boat upholstery? The thread is the concern.
Probably a good idea to test it in an inconspicuous area first if you can.
Reactions: CumminsPusher
Well, you can't tell that way on boat upholstery, if it's damaging it will be to the thread and you won't know until it turns loose and the seams begin to spread. I just thought perhaps you or someone else may know if it's safe. Thanks.
Tbowman053
Tbowman053
Henderson, MD
Well the super clean worked great!! even did the black plastic on outside
20170214 111801
20170214 111719
