P1000 Roll cage removal for transport
OnTheJob
OnTheJob
426
925
Bristol, NY
Sorry for not introducing myself but hoping someone here may know the answer before I go pick this beast up. I just bought a new Pioneer 1000 (3p). I'm going to pick it up Tue/Wed. I've got a heavy duty enclosed trailer 66" high, 65" wide and plenty long. Obviously if I want to use my trailer I'll have to take off the roll bar for this one time transport. Has anyone completely removed the roll bar for what ever reason? Is it a PIA and can I do it with a socket set and a driver? I have a buddy that has an open landscape trailer I can barrow but it's going to add a lot of time to my pick up process.
Thanks guy!
J Law
Rochester, NY
Neohio
Neohio
Beast of the East
14,587
73,831
Painesville Ohio
It can be removed with out too much issue. Decent socket set will remove it. Just confirm you have 10/12/14/17/19 sockets and wrenches and you should be able to do 90% of your work.
Neohio
Neohio
Beast of the East
14,587
73,831
Painesville Ohio
Honestly, not entirely sure. Always some dumb little thing over looked.
Lets say 10% specialty tools? Internal engine stuff etc.
Edit, 30mm axle nut socket comes to mind immediately, also cotter pin puller, side cutters etc. general hand tools.
E
elkguide
3,377
7,964
Vermont
Good idea to bring a few "extra" tools 'cause as they say......."things do happen!"
Neohio
Neohio
Beast of the East
14,587
73,831
Painesville Ohio
Metric allen keys. 5mm and smaller. Service jack and stands. The sockets are the cheapest part of this.
Did you buy a 16? 17? 18?
A service manual is invaluable. I reference mine pretty much weekly.
66,870
lol... I think he meant just for the cage.. not the entire machine. haha.
Neohio
Neohio
Beast of the East
14,587
73,831
Painesville Ohio
Just ran outside to not scare you. 14mm and 17 mm socket. The nut on the cage is nylon locking. So have 2 ratchets if you have the tools.
Reactions: JTW and elkguide
E
elkguide
3,377
7,964
Vermont
You had me scared and I'm not taking mine off!!!!!
Reactions: Mudwing
HondaTech
Just be careful with the upper seat belt bolts. Alot.of guys don't clean these threads before installing the bolts and you end up with a stripped bolt and screwed up threads. These bolts can't be bought without getting the whole seat belt assemblies (at least not from Honda) and aren't metric thread. I think their 7/16-20 pitch.
3 seaters only have 10 bolts holding the cage to the unit. 4 more to split the front and rear.
5 seaters have 16 holding it to the unit. 8 holding the front, middle, and rear together. Not including the seatbelts, the nets can be left on there respective roll bar.
jinx
jinx
565
528
How much is "add a lot of time to your pick up process"?
It may be quicker and less cursing to borrow your buddies trailer vs disassembly/reassembly. Not to mention the possibility of loosing or ruining fasteners in the process.
Reactions: swsebek
OnTheJob
OnTheJob
426
925
Bristol, NY
Solution: Landscape trailer. What I didn't take into consideration; where do I put the roll cage for the transport unless I COMPLETELY break it down. The trailer is 12' long so I don't know if it will fit and I don't want to jam it in there scratching everything up. Thanks guys for helping make this decision!
FYI: I posted the same question to hondapioneerforum and got 29 views with no responses. I know which forum I will be using from here forward.
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
He will also need a 19 for the a pillar nuts. I've removed mine more times than I care to count. It's not a big deal, you'll be fine.
E
elkguide
3,377
7,964
Vermont
I'm going with the borrow a buddy's trailer method.
Reactions: Delton
swsebek
swsebek
2,854
5,835
pa
Wise choice. And I wanted to welcome you from Pa and congrats on the ride.
This site is it for responses to your posts and just out right valued info.
Post up some pics and let us know what happens
Neohio
Neohio
Beast of the East
14,587
73,831
Painesville Ohio
@OnTheJob Was not my intention to scare you with all the tools.
I agree with everyone else, landscape trailer is the way to go. Just tried to help with tools you may need in the future.
I believe I read that you bought a ‘16. Consider becoming either a supporting member, or lifetime. There is a pdf service manual available for members. Someone did some deep googling and posted it for us.
Welcome to the club, enjoy your new machine!
Stevo
Stevo
86
143
Illinois
I think that is the right choice. When I got my pk100 the dealer broke one of the bolts holding netting then jimmied hole trying to get broken bolt out so they took off roll cage off another one to replace mine. I helped in the procedure. Was not that hard but roll cage is cumbersome and you could chip paint on roll cage if not very careful defiantly a two person job. IMO
