P1000m3 Roll over found!! No fail!
320,458
Yes of course there are variables as I pointed out. Also speed would probably be a factor.o_O But this at least gives a static demonstration and a starting point. When you get to 40+ degrees you better start paying attention.
Yep I'd say 40 is average pucker factor!
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
I know you'll go farther than that... come on over to the Ridge we'll both run the tram road to the cement building. I'm sure it's getting real close to the 45 mark there... I've done it once, you can do it too
I'm alot better following someone like we did when @Manwell showed up last winter. I'm the first to admit that puckers me up tight. I still do it though.
Ragnar406
Ragnar406
The Great Bald One
4,446
17,020
Bella Vista, AR
@Ragnar406 @Tigermark I knew we could go past 42 degrees. That what the ravine is on long and nasty at rush springs. Haha
You ready for that @Montecresto @my99svt @Tramguage1
Yep- that don't really want to lean that much further - I am sure that tires, passangers, weight etc. affect it & @Tigermark had a lift too
Reactions: sharp and drfubar
drfubar
drfubar
TheDonFather
5,889
19,233
Mary's Ridge (Dayton Mtn), TN
yeah, don't forget those pretty whippy things that make all the guys go OHHHHHHHHHHH.o_O They might get him turned over quick too.:rolleyes:
Tigermark
Tigermark
Outside looking in.
You just have the camera readyo_O @Ragnar406 and @nbomar and I !
Dean1K3
Dean1K3
38
68
Osteen Fl.
o_OOk here ya go. My Pioneer will tip at one degree over what the video shows. I tried it several times and it will go over at anything over 47-degrees. When I'd get it to 48 it would start over on it's side and the tractor is the only thing that kept it from going farther. Your Pioneer may tip over a little soon or or a bit after but I'm willing to bet it won't be more than a degree one way or the other. 47-degrees is somewhat of a balancing point, 48 it wants to roll. I'd say when you get up around 45-degrees you better start leaning to the inside boys.;)
Lol wow I'll stick with the flat water
swamps
266,529
@drfubar you need to lift passenger side with driver in it. Both times mine tipped on drivers door far less than 40 degrees. I'm sure your wife will volunteer to sit in SXS o_O
Bayouownbeer
Bayouownbeer
786
1,061
Chauvin LA
Cool vid thanks bud
Reactions: drfubar
silverbullet
16
Leitchfield, KY
What Garmin are you using ?
What
Reactions: drfubar
