roof rack on a 4 seater
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
so im thinking of making a roof rack and bolting it to the roof bolts for the honda roof.
anyone have thoughts on this? thinking of carrying my misc stuff that i rarely use up there.
NTCPrezJB
NTCPrezJB
President of #NTC
100,625
899,186
Canton, OH
The biggest concern for me would be raising the cog. If you aren't in hill climbs or off camber stuff that wouldn't matter so much to you.
Russ989
Russ989
22,569
146,535
X2, is like to see it but not sure if the juice is worth the squeeze.;)
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
raising the cog?
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
never mind. well ill be moving weight give or take about 50 lbs max from 4.5 ft off the ground to 7.5 ft off the ground.
Reactions: NTCPrezJB
NTCPrezJB
NTCPrezJB
President of #NTC
100,625
899,186
Canton, OH
raising the cog?
COG=Center of gravity
The higher you have weight the more tendency they have to tip.
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
yeah didnt register at first. thats not an issue for me. i do alot of off camber and climbing but im also alot wider and taller than the regular 700. so that ships done sailed.
NTCPrezJB
NTCPrezJB
President of #NTC
100,625
899,186
Canton, OH
Gotcha. You can always throw stuff in a tote and strap it to the roof for a trial run on your favorite trail if you wanted to be sure before you invest time in making it right.
I would think fabricating the rack to bolt up as you are thinking would work fine though. Might cut a piece of old inner tube to throw between your mounting tabs and the cage so you don't rub paint. (I'm assuming you are bolting it up because you want to be able to remove it at times.) You will probably need to get longer bolts anyway so another few mm's won't hurt anything.
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
yeah but not big stuff. i have a small pit in a carrying bag be nice to put it up there to keep mud off of it. or my jumper cables. and a small tool kit. stuff like that. im thinking 50 lbs would be max load out including the rack weight.
320,014
My local buddy built this. Don’t seem to have any real good pics but at least for basic idea. He built it separated so can take the back ROPS section out.
6200F9C8 1930 42EC A5C2 BFC11993486D
9E1AABE5 9BF1 4A6E BD49 3A0EC02C7826
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
dam yeah i like that alot more than i would put up there. lol
