P1000 Roof
Sb82
Sb82
17
30
Illinois
I just purchased an 18 1000-5 deluxe. I have ordered a kolpin steel roof that is made of 14 gauge steel. I was concerned after I ordered that this may be to heavy on top. Does anyone have experience with this roof or a similar steel roof and any issues with it being to heavy?
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
How much does it weigh? Vs plastic or aluminum
Reactions: Remington
Sb82
Sb82
17
30
Illinois
I’m not sure. Just got the shipping quote saying the shipping weight is 180 lbs. I have not been able to find any reviews on this roof anywhere.
Sb82
Sb82
17
30
Illinois
I emailed kolpin and they said total shipping weight including the pallet was 112 lbs. So hopefully this won’t be to heavy
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
you could always put heavier tires on it to help balance it out.
Redmoon
Redmoon
265
456
Prescott Az.
If the pallet is 80 lbs that means that your roof is still going to be 32 lbs. Mounted at the highest point on the machine. Is it too late to cancel? There are much better weight options available.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Have any of you picked up the Honda roof. They weigh more than the cage does. I think you'll be fine with what you ordered but it will be loud.
if its steel its gonna be heavy, another member had a 3/16 steel roof on his 3 seat and it was 75lbs I imagine about 80lbs would be rich for a steel roof on a 5 seat.
Gonna be LOUD too, the honda roof isn't bad weight wise its probably in the 30-40 lbs range its just really awkward by yourself getting it on because its flexible and large.
Reactions: Cyberjunk
