P1000 Rubicon05 p1000-5 build
rubicon05
rubicon05
234
310
Southern, IN
got a few more things done over the past few weeks....winch installed - Warn 4500S
Reactions: Tot
rubicon05
rubicon05
234
310
Southern, IN
10" & 50" Rigid Radiance Light bars and Rigid A-series Rock lights wired up - they are all blue back lit
rubicon05
rubicon05
234
310
Southern, IN
Rigid A-series mounted below taillights - wired into the back up alarm wire so they only come on in reverse.....
also forgot to post a pic of the 10" & 50" bars lit up.....think i may end up picking up some cubes to angle out like a few others have done.
Reactions: Tot
rubicon05
rubicon05
234
310
Southern, IN
finally put 40 miles on last weekend too....mainly backroads, but so far i'm pretty damn impressed with this machine!
rubicon05
rubicon05
234
310
Southern, IN
next on my list is a roof and skid plates but still undecided on them as far as what to get. I'm not a big fan of the factory Honda roof. Both are big $$ so i want to make sure i get it right:)
dale5740
dale5740
886
417
mt airy md
how was it for using the back up alarm to run reverse lights? can u do that without factory switch panel if so what do u need?
Jeffro
106
47
Louisiana
I'd like more info about wiring the reverse lights into the backup alarm also. For those lights, did you just have to drill the two holes for the screws to mount them?
rubicon05
rubicon05
234
310
Southern, IN
I drilled 3 holes....2 holes to mount and 1 hole to run the wires through. I just spliced into the backup alarm plug.....it's in front of the driver side rear tire. A quick search on here and you can see a pic that @Hondasxs posted.
Jeffro
106
47
Louisiana
Thanks, I found it. I really like that idea and those lights look great there. I need to copy that but those Rigids are high. I wonder if there are any cheaper ones made like that. I'll have to look for some or just bite the bullet and buy those since they look so good!
rubicon05
rubicon05
234
310
Southern, IN
Do a quick search on Amazon for led rock lights...I just prefer rigid brand!
Similar threads
