S&S a-arm guards
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Got a set of s&s fab black powder coat arm guards. Put them on last april. They are use so they gotta few scratches an dings but all the welds are solid. Have all hardware too. Prefer local pickup..would meet at a reasonable distance. Im in Greenville ,Mo...Price was 250 new....ill take 150.
20171222 202347
20171222 202451
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
View attachment 60325 View attachment 60326
Need to repaint them. you don't need them?
208,730
Going with arched a arms so i wont be able to use them
When I installed mine, Rear.I took shock lose, can't mention the brand @my99svt is sensitive to this. Then the top bolt out of the top of the knuckle, when I removed the bolt the top A arm sprung up about 2 inches. The rear top A arm was in a bind, the factory bushing doesn't float, the movement of the arm was in the rubber bushing twisting.I would think this wouldn't let the suspension work properly. Or maybe the A arm bolts were too tight. You guy's running factory A arms might what to check this all the way around.
