Same size tires on 1000-5
Hunt1940
14
Westwood NJ
I see a lot of questions about running the same size tires on all 4 corners . My question is . Can I run the rear size tire on the front ? All stock no off sets etc . Just put on the same all the way around.?
JenElio
JenElio
73,432
667,863
Loxahatchee, florida
First post......welcome from south FL
12" or 14" wheels?
I believe 12" you can but you'll need a 1" spacer up front so it clears. And if you want to somewhat keep even(ish) track then a 2" spacer on the rear.
Oh and...........Pics or it didn't happen!!! 😂😂
Hunt1940
14
Westwood NJ
12" or 14" wheels?
Stock wheels ...looking to put the same
Size tires all around.
115,791
Refer to post #4 & #6 First. ;)
Yes you can run the same size all the way around. But you cant put 2 rears (like rims) in the front. You will rub calipers. Thats why if your stock, we keep a “front” key word
spare, cuz it will work on front or rear.
#POIDH
179,043
Don't know the specific spacer set up and all that for the P1 but running the wides on the front makes it a little floaty. Especially in the turns. It looks BA and you can get used to it but it honestly performs better with skinnies on the front. You can run skinnies on all four but lose some flotation that way. Now I'm running 10's on all four and run a bit higher psi on the fronts. I'm happy with it.
115,791
Yeah like @trigger mentioned about spacers. Regardless of what same size all the way around wheel set up your doing, you will need spacers to fix the track. @RB3offroad can hook u up with a set. Dont worry it wont hurt your machine and a 4th grader can put them on. Now that you have all this welth of knowledge, your thinking…Holy Crap my pants Batman! Now i need new wheels and tires should I ask them that? The answer is a Negative! Search up too for wheels and tires and Blow your mind 🤯
JenElio
JenElio
73,432
667,863
...... Dont worry it wont hurt your machine and a 4th grader can put them on......
78425
You hear that @TripleB!!! A 4th grader can put them on bro!!! 😂😂😂
Russ989
Russ989
22,642
147,257
You need to swap A-arms if you’re wanting to go up in tire size. You’ll definitely need spacers. It’s the only way to go in my opinion.
A
ADVBUM
64
245
Arkansas
What combo of 10's? Offset, rim width, tire size and spacers? TY
