Second thoughts on my P700
43,070
I am wishing that I had got a 1000. But, all I do is use it for hunting. So, somebody set me straight. I have no legit reason. I think it simply just because 1000 is out there.
If all you are doing is hunting, then I'd think it'd be easy to be satisfied with the 700. Try here!
On the other hand, I'd always recommend you get what you want rather than settle for what you have. It's unlikely anyone is going to change that.
Russ989
Russ989
22,642
147,257
I just posted my 700-4 for sale, if all I did was hunt and do some utility work then it would be more than enough for me. After going to the takeover this year I’ve had the itch for a 1000 but only because of the suspension and low range. The 700 is truly a great machine.
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
iv had the 700-4 since 14. change the oil. change the diff oils if submarining. and change brakes. itll take you where ever your stand is and then some. i use mine for hunting and mud riding trail riding. spulunking. on a side note my dad has big red 2013 model with stock tires he uses for everything as well. couldnt be happier with the capability to go to woods for a fun ride or to get that meat brung back home. well unless you want to do it at 50 mph then you need the 1000.
