im putting a fuse block, ground bus, battery isolator, and winch contacter under my hood. Most items are going to be in places where they will be attached to the plastic panels. Winch contacter over by the factory ground, ground bus next to the air cleaner, isolator in that little indent behind the factory “tool kit”, fuse block behind the second battery.
How’s everyone doing this? Sheet metal screws right into the plastic seems easiest but may not stay secure? Machine screws with nuts on the back? Double sided tape?
