Securing switch panel?
03mossy
03mossy
275
1,080
MN
  2. Other Brand
What does everybody use to secure your switch panels in the dash? I want something that can be removed fairly easily as I’ll be adding accessories over time and need access to it.
Reactions: Isaiah and Mudwing
Mudwing
Mudwing
36,959
306,563
The Mud holes
01FCCB74 D222 4313 9B88 866CC25A2F39
I used the plastic push pins to secure my switch panel. 😉😎
03mossy
03mossy
275
1,080
MN
  2. Other Brand
Ok here’s a rookie question. I bought a 100 pack of the Honda push pins figuring this d need them for different add ons. What size drill bit do I use? I used them to add rear cup holders and first ride out with them they both fell off. Guessing i used to big of a drill bit.
NTCPrezJB
NTCPrezJB
President of #NTC
101,487
906,577
Canton, OH
Last time I put one in a new spot I pulled one of the factory ones and sized my drill bit based on that hole.
Mudwing
Mudwing
36,959
306,563
The Mud holes
There are different sizes out there. Can you post the part number of the ones you have?
Reactions: Isaiah
03mossy
03mossy
275
1,080
MN
  2. Other Brand
Reactions: Isaiah
Mudwing
Mudwing
36,959
306,563
The Mud holes
I’m not sure but I think I used a 5/16” drill bit. I’ll check later. 10mm is smaller than 7/16” 😉
Reactions: Isaiah and JenElio
Ohio4x4
Ohio4x4
I brought the dishwasher
1,495
15,026
I use pushpins also.
Never use rivets. You will be drilling them out before the end of the week.
Short screws work great in place of rivets.
I second this. I was all proud off my set up and riveted the panel in only to find I had accidentally unplugged a hot to one switch. Lol. Its screwed in now for easy access.
Coeus
Coeus
Major General
59,270
592,498
Signal Mountain, TN
  2. Talon R4 LV
I use rivet nuts and small Allen head screws. Some people call them nutserts.
@TripleB what size did you use? I am trying in the scrap plastic and they don't bulge behind the plastic.
TripleB
TripleB
11,932
101,041
Caryville, Tennessee
I'm not sure. I will try and look tomorrow. I'm thinking m5 but that might be way off.
Prntckt
Prntckt
1,049
7,226
Altoona, WI
I used these rivnuts from McMaster Carr that are designed for soft materials. Secured the panel with 10-32 allen head socket cap screws.
3F8ED769 7BC2 466D BBAF 1B0EAE34913A
