September ROTM - Chooglin
September ROTM Voting
  • CumminsPusher
    Votes: 6 21.4%
  • SuperYeti
    Votes: 2 7.1%
  • Chooglin
    Votes: 9 32.1%
  • iowaguy
    Votes: 2 7.1%
  • jak9922
    Votes: 3 10.7%
  • LittleRedWagon
    Votes: 1 3.6%
  • bigdeal
    Votes: 0 0.0%
  • Windrock1000
    Votes: 1 3.6%
  • sporttrac4x4
    Votes: 3 10.7%
  • sharp
    Votes: 6 21.4%
  • Remington
    Votes: 4 14.3%
  • JTW
    Votes: 6 21.4%
  • ghost
    Votes: 1 3.6%
  • jawquin
    Votes: 2 7.1%
  • Total voters
  • Poll closed .
67,231
Sorry for the short entry deadline... We will get October back on track with a full timeline.
Entry is simple, just post a picture in this thread to make your submission.
You may post up to 3 pictures if you like.
Posting your picture in this thread enters you into the contest.
OPEN POST - No theme this month!
THE PRIZE -
We are giving away a set of RGB Color x4 Rock Light Kit as seen here --> RGB Bluetooth Control Universal Fit LED Rock Light Kits
*NOTE: You must have a smartphone to control the RGB. Otherwise, I can send a single color kit!
811YgwWgqiL SL1500  1
More info on the light kit here --> RGB Bluetooth Control Universal Fit LED Rock Light Kits
Run the show:
1, Let your travel fascinating with 4 pocket-sized pods.
2, Control the neon lights with your cell phone APP.
3, DIY to get 16 million colors.
4, Different with others, just show yourself.
Durable design:
1, Wrapped in a protective polymer to prevent any water, dirt, or excessive heat damage.
2, 50, 000 hrs life span.
3, PC lens of LED light thick reinforced, long-term use does not exist lens yellowing.
4, Die-cast aluminum shell with thick materials, good heat dissipation, light decay, paint dusting aging, permanent will not fade.
Specifications:
1, Power: 9W.
2, Operating Voltage: DC 9-32 V.
3, Current draw: 0.75A at 12V, 0.37A at 24V.
4, Waterproof rate: IP68.
5, LED: 3 pcs X 3W CREE chips.
6, LED Color: RGB 16 million colors.
7, Lumens: 650 LM.
8, Housing material: Die-cast aluminum.
9, Lens material: PMMA.
10, Mounting bracket: rubber.
11, Optional beam: 150-degree flood beam.
12, Lifetime: 50,000 hours.
13, Product weight: 2.82 pounds.
Complete 4 pods rock lights kits includes:
4 X aluminum LED pods
11.5 stiff wire every pod for mount
1 X solid Bluetooth receiver
4 X 2 ways rubber, screw and shim for install[/SPOILER]
TIMELINE -
Submission must be made by October 2nd by 9pm EST.
Once the submission is closed we will attempt to narrow the field down to the top 10 of our liking.
Shortly after voting will begin. Voting will last 5 days. Highest vote counts wins.
GOOD LUCK!
**** UPDATED RULES ****
Full rules here --> RULES - ROTM - Ride of the Month! - UPDATED
***** Sponsors Wanted *****
If you are in need of product marketing and interested in sponsoring an ROTM we would like to discuss it with you.
Reactions: CumminsPusher
67,231
Voting now open...
Let's give it 5 days.
- Decided to keep all the entries.
- You can vote for 2!
Remember, If you are on TAPATALK you must view it on the webpage to find the voting. Its above post #1!
322,675
oh yeah baby i was let it
That's cool too with a crf! @Hondasxs not positive how to vote here.
